ACMER
ACMER ASCARVA 3S
Entry-level, modular CNC router with a 500W spindle and ESP32 control
An ACMER ASCARVA 3S CNC machine.
The ACMER ASCARVA 3S is a DIY, modular CNC router with a 300 x 180 x 78 mm working area and a 500W spindle rated to 12,000 RPM (plus or minus 0.025mm accuracy). It runs the X, Y, and Z axes on lead screws riding on twin hardened round rails in an all-aluminum body, and ships with an E-stop, six limit switches, and a tool setter for zeroing.
The ASCARVA 3S’s 500W spindle tops out at 12,000 RPM, below the chart’s typical 16,000 RPM recommendation for hard wood with a small end mill, so cap the spindle at 12,000 and use feed rate to control the cut. Depth per pass is where the machine itself matters. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. The ASCARVA 3S is a light, modular DIY frame, so treat it like a lighter machine: take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the ACMER ASCARVA 3S. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The ACMER ASCARVA 3S runs ESP32-based firmware, connecting over USB and controlled through GRBL-style senders such as Candle or UGS. Easel’s live control, the Easel Driver and Rapid Connect, works with classic GRBL and FluidNC over USB, so it does not carve this machine in real time. Use Easel to design and generate toolpaths, then export the G-code and run it from the machine’s own controller software, such as Candle or UGS. Because Easel’s G-code is standard GRBL, it runs as-is on these senders. Select ACMER ASCARVA 3S in Easel’s machine menu to size the canvas.
