ACMER
ACMER ASCARVA 4S
Pre-assembled CNC and laser hybrid with a 70W spindle, upgradeable to 500W
An ACMER ASCARVA 4S CNC machine.
The ACMER ASCARVA 4S is a pre-assembled CNC router with a 70W spindle standard, upgradeable to 500W, controlled from an onboard 3.5 inch touchscreen with a manual Z-knob. It has a 400 x 400 mm (15.75 x 15.75 in) work area, runs the X and Y axes on GT2 6 mm timing belts with steel V-wheels and the Z axis on a lead screw, and supports 5W and 10W laser modules, so the same frame can also run as a laser engraver.
ACMER does not publish a spindle RPM for either the 70W stock spindle or the 500W upgrade on the ASCARVA 4S, so check the plate on your spindle before you start and use its actual top speed in place of the chart’s number if it runs lower. Depth per pass is where the machine itself matters. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. The ASCARVA 4S is a pre-assembled, touchscreen-controlled machine built around a small 70W stock spindle, so treat it like a lighter machine and take shallower passes, especially before upgrading to the 500W option. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the ACMER ASCARVA 4S. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
ACMER does not state the ASCARVA 4S’s firmware, but it connects to Easel as a standard GRBL device over USB, so it works directly with Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender, or run jobs standalone from a TF (microSD) card via the machine’s onboard touchscreen. Select ACMER ASCARVA 4S in Easel’s machine menu to size the canvas.
