AnoleX no longer sells this model, but it remains fully supported in Easel. The 3020-Evo has a 287 x 196 x 73 mm working area, a 300W spindle upgradeable to a 65mm router, and dual steel linear guide rails on the X and Z axes.
The 3020-Evo’s spindle is a 300W unit, and AnoleX does not publish a max RPM for it, so check the rating plate on your spindle before you start. A spindle this size is light duty: it loses torque fast once you push speed and load together, so keep the feed rate doing the work rather than cranking the spindle. The dual steel linear guide rails on X and Z keep the machine accurate, but this is still a compact desktop router, not a heavy industrial frame. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. The 3020-Evo falls short of that bar, so take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the AnoleX 3020-Evo. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The AnoleX 3020-Evo runs GRBL 1.1h, so it connects directly to Easel, even though AnoleX no longer sells this model. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender. Select AnoleX 3020-Evo in Easel’s machine menu to size the canvas to its 287 x 196 x 73 mm working area.
