AnoleX
AnoleX 3060-Evo Pro
All-metal CNC with a 300 x 600mm working table
An AnoleX 3060-Evo Pro CNC machine.
AnoleX no longer sells this model, but it remains fully supported in Easel. The 3060-Evo Pro has 287 x 600 x 73 mm of XYZ travel on a 300 x 600 mm table, dual steel linear guide rails on all axes with T8 lead screws standard, and Nema 17 steppers rated 650 mN·m. It ships with a 300W spindle. AnoleX does not state the spindle’s top RPM on this model’s page.
The 3060-Evo Pro ships with a 300W spindle, but AnoleX does not publish its top RPM, so check the rating plate on your spindle before you start. Dual steel linear guide rails on all three axes keep it accurate, but the long 600mm Y travel gives the gantry more room to flex than a compact format, and this is a desktop machine, not an industrial frame. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. The 3060-Evo Pro falls short of that bar, so take shallower passes, especially toward the far end of the gantry. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the AnoleX 3060-Evo Pro. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The AnoleX 3060-Evo Pro runs GRBL (AnoleX never published an exact version number on its archived product page, but the machine connects to Easel as a standard GRBL device over USB), so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender. Select AnoleX 3060-Evo Pro in Easel’s machine menu to size the canvas to its 287 x 600 x 73 mm working area.
