AnoleX
AnoleX 4030-Evo Ultra
All-metal CNC with a 500W spindle and ball-screw drive
An AnoleX 4030-Evo Ultra CNC machine.
AnoleX no longer sells this model, but it remains fully supported in Easel. The 4030-Evo Ultra runs a 500W spindle rated at 10,000 RPM with an ER11 1/8in chuck, HGH-15 dual linear guides and 1204 ball screws on all axes, and Nema 23 steppers rated 2.8A, 1.2 N·m. Its working area is 400 x 300 x 130 mm (15.7 x 11.8 x 5.1 in).
The 4030-Evo Ultra’s 500W spindle is rated at 10,000 RPM. Its HGH-15 dual linear guides and 1204 ball screws on all axes are the most rigid drive AnoleX offers on this format, and the Nema 23 steppers give it more torque than the smaller 3030 and 3060 machines. That combination can support deeper passes than a belt- or lead-screw machine, but a truly rigid setup capable of cutting as deep as the bit is wide in one pass also needs clamps that hold firm and enough mass to soak up vibration, so still work up to depth rather than assume it. Push too deep too fast and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the AnoleX 4030-Evo Ultra. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The AnoleX 4030-Evo Ultra runs Grbl_ESP32 (GRBL 1.3a). Easel’s live control, the Easel Driver and Rapid Connect, works with classic GRBL and FluidNC over USB, so it does not carve this machine in real time. Use Easel to design and generate toolpaths, then export the G-code and run it from the machine’s own controller over USB or WiFi using the ESP3D web interface (or SD card). Because Easel’s G-code is standard GRBL, it runs as-is. Select 4030-Evo Ultra in Easel’s machine menu to size the canvas.
