AnoleX
AnoleX 4030-Evo Ultra 2
All-metal CNC with an 800W trim router and ball-screw drive
The 4030-Evo Ultra 2 runs an 800W trim router (6-speed, 8,000 to 24,000 RPM) on a 65mm mount, HGH-15 dual linear rails and 1204 ball screws on all three axes, and Nema 23 steppers rated 2.8A, 1.2 N·m. AnoleX does not state a working area for this model on the current product page.
The 4030-Evo Ultra 2’s 800W trim router runs 8,000 to 24,000 RPM across its six speed settings, covering the full range of the chart below and then some. Its HGH-15 dual linear rails and 1204 ball screws on all three axes, driven by Nema 23 steppers, are the most rigid combination AnoleX offers, which supports deeper passes than a lighter lead-screw machine. A truly rigid machine capable of cutting as deep as the bit is wide in one pass also needs clamps that hold firm and enough mass to soak up vibration, so work up to depth rather than assume it on the first pass. Push too deep too fast and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the AnoleX 4030-Evo Ultra 2. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The 4030-Evo Ultra 2 runs Grbl_ESP32 (GRBL 1.3a). Easel’s live control, the Easel Driver and Rapid Connect, works with classic GRBL and FluidNC over USB, so it does not carve this machine in real time. Use Easel to design and generate toolpaths, then export the G-code and run it from the machine’s own controller through the ESP3D web interface (or SD card) over WiFi. Because Easel’s G-code is standard GRBL, it runs as-is. Select 4030-Evo Ultra2 in Easel’s machine menu to size the canvas.
