AnoleX
AnoleX RX6040
All-metal CNC with a 1.5kW spindle and ball-screw drive
An AnoleX RX6040 CNC machine.
The RX6040 has a 600 x 400 x 130 mm effective processing area. It runs a 1.5kW spindle (65mm) with ER11 1/8in and 1/4in collets up to 24,000 RPM, HGH-15 dual linear rails and 1204 ball screws on all three axes, and Nema 23 steppers rated 2.8A, 1.2 N·m.
The RX6040’s 1.5kW spindle runs up to 24,000 RPM, covering the full range of the chart below and then some, and it holds more torque under load than the smaller trim-router-based machines in AnoleX’s lineup. Its HGH-15 dual linear rails and 1204 ball screws on all three axes, driven by Nema 23 steppers, are a rigid setup for a desktop machine, which supports deeper passes than a lighter lead-screw or belt-driven router. A truly rigid machine capable of cutting as deep as the bit is wide in one pass also needs clamps that hold firm and enough mass to soak up vibration, so work up to depth rather than assume it on the first pass. Push too deep too fast and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the AnoleX RX6040. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The RX6040 runs Grbl_ESP32 (GRBL 1.3a) over WiFi, controlled through its onboard ESP3D web interface, with no USB cable required. Easel’s live control, the Easel Driver and Rapid Connect, works with classic GRBL and FluidNC over USB, so it does not carve this machine in real time. Use Easel to design and generate toolpaths, then export the G-code and run it from the machine’s own controller (the ESP3D web interface or SD card). Because Easel’s G-code is standard GRBL, it runs as-is. Select RX6040 in Easel’s machine menu to size the canvas to the 600 x 400 x 130 mm working area.
