BlueCarve
BlueCarve Full Sheet Trax
Full-sheet CNC router with rack-and-pinion drive and closed-loop steppers
A BlueCarve Full Sheet Trax CNC router with an aluminium frame.
The Full Sheet Trax is BlueCarve’s full-sheet CNC router, with a 1500 x 3000mm rail size and a 1270 x 2770mm cutting area (105mm height clearance). It ships with a 65mm spindle mount sized for a Makita RT0700 trimmer (a 1.5kw or 2.2kw air-cooled spindle and VFD is an optional upgrade), 330ozin closed-loop steppers with an 8mm shaft on all three axes, and a 20mm helical rack-and-pinion drive on X and Y riding on 15mm linear rails.
BlueCarve does not state a maximum RPM for the Full Sheet Trax’s spindle mount, since it ships bare for a Makita RT0700 trimmer or an optional 1.5kw/2.2kw upgrade spindle, so check the plate on whatever spindle you install. The 20mm helical rack-and-pinion drive and 330ozin closed-loop steppers make this a rigid, full-sheet machine, which supports more depth per pass than a light desktop router, but a truly rigid, powerful setup that can cut as deep as the bit is wide in one pass still needs the drive train, clamps, and gantry to all hold firm and enough mass to soak up vibration. Push too deep on any machine and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. Start conservative and work up. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the BlueCarve Full Sheet Trax. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The BlueCarve Full Sheet Trax runs FluidNC. Easel’s live control, the Easel Driver and Rapid Connect, works with classic GRBL and FluidNC over USB, so it does not carve this machine in real time. Use Easel to design and generate toolpaths, then export the G-code and run it from the machine’s own controller (the FluidNC web UI or its touchscreen). Because Easel’s G-code is standard GRBL, it runs as-is. Select BlueCarve Full Sheet Trax in Easel’s machine menu to size the canvas.
