Bob's CNC
Bob's CNC KL744
Large-format CNC kit with closed-loop servos and a 1219 x 1219 mm bed
The KL744 is BobsCNC’s largest kit, with a 1219 x 1219 x 127 mm working area and 114 mm of gantry clearance. It drives X and Y on a steel-reinforced Bell-Everman servo system with NEMA 23 closed-loop servo steppers (425 oz-in / 3 Nm holding torque), a ball screw on Z, and ships with a Makita RT0701C router rated 10,000 to 30,000 RPM. It runs GRBL 1.1 firmware on an Uno controller.
The KL744’s Makita RT0701C router runs from 10,000 to 30,000 RPM, comfortably above every speed on the chart, so you can run the chart’s recommended RPM directly instead of capping it. It pairs closed-loop NEMA 23 servo steppers and a steel-reinforced Bell-Everman drive on X/Y with a ball screw on Z, a much stiffer build than a belt-and-acme-rod kit, even at this larger 1219 x 1219 mm bed size. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. The KL744’s closed-loop servos and ball-screw Z put it closer to that bar than a lighter kit, but it is still a hobby machine, not a production mill, so build up to full-diameter passes gradually rather than assuming it from day one. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the Bob’s CNC KL744. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The KL744 runs GRBL 1.1 on an Arduino Uno controller, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender. Select KL744 CNC Router Kit in Easel’s machine menu to size the canvas to its 1219 x 1219 x 127 mm working area.
