Carbide 3D
Carbide 3D Nomad 3
Fully enclosed desktop CNC mill with a 130W brushless spindle
The Nomad 3 is Carbide 3D’s fully enclosed desktop CNC mill, with an 8 x 8 x 3 in working area, a 130W brushless DC spindle (9,000 to 24,000 RPM) with an ER-11 collet (7mm max cutter diameter, collet not included), and HG15 linear rails on the Z-axis with anti-backlash nuts on every axis.
The Nomad 3’s spindle runs 9,000 to 24,000 RPM, comfortably above the chart’s suggested speeds, so you can run the chart’s recommended RPM directly without hitting a ceiling. It’s a fully enclosed desktop mill: HG15 linear rails and anti-backlash nuts on every axis give it good rigidity for its size, but it’s still a light machine, not an industrial one. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. The Nomad 3 falls short of that bar, and the fix is simple: take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the Carbide 3D Nomad 3. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Nomad 3 runs GRBL on an Atmel 328 (Carbide Motion Board), so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender. Select Nomad 3 in Easel’s machine menu to size the canvas to its 8 x 8 x 3 in working area.
