Carbide 3D
Carbide 3D Shapeoko 4
Best-value desktop CNC router in three sizes, V-wheel and belt drive
A Carbide 3D Shapeoko 4 CNC machine.
The Shapeoko 4 comes in three sizes: Standard (17.5 x 17.5 x 4 in), XL (33 x 17.5 x 4 in), and XXL (33 x 33 x 4 in). It uses a 65mm trim router as a spindle (not included, upgradeable to the Carbide VFD Spindle), Heavy-Duty V-wheels on 15mm belts for X/Y, and a leadscrew-driven Z-Plus Z-axis with heavy-duty linear bearings. Takes about 2-3 hours to assemble.
The Shapeoko 4 ships without a spindle: you supply a 65mm trim router (the Carbide Compact Router or a compatible router like the Makita RT0701C), or upgrade to the Carbide VFD Spindle, so your actual RPM depends on what you install. Heavy-Duty V-wheels on 15mm belts and a leadscrew Z-Plus Z-axis give it a solid base for a desktop machine, but it’s not a rigid industrial frame, especially on the larger XL and XXL sizes. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. The Shapeoko 4 falls short of that bar, and the fix is simple: take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the Carbide 3D Shapeoko 4. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Shapeoko 4 runs GRBL 1.1 on its Carbide Motion controller board, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender, such as Carbide Motion. Select Shapeoko 4, Shapeoko 4 XL, or Shapeoko 4 XXL in Easel’s machine menu to match your machine’s working area.
