Carbide 3D
Carbide 3D Shapeoko HDM V3
Heavy-duty water-cooled CNC built for cutting metal
A Carbide 3D Shapeoko HDM V3 CNC machine.
The Shapeoko HDM V3 is Carbide 3D’s heavy-duty machine for cutting metal, with a 690 x 610 x 145 mm (27 x 24 x 5.7 in) working area, a 4-pole 80mm water-cooled VFD spindle with a chiller (1.5kW at 110V or 2.2kW at 220V, 8,000 to 24,000 RPM, ER-20 collet, max 13mm/0.5in tool), and 16mm ball screws with HG-15 linear bearings on every axis. It ships fully assembled, aligned, and tested in-house, delivered by freight on a pallet.
The Shapeoko HDM’s 4-pole water-cooled spindle runs 8,000 to 24,000 RPM with real torque behind it, comfortably covering the chart’s recommended speeds. Ball screws and HG-15 linear bearings on every axis, plus a frame built and tested for cutting metal, give it the rigidity to take deeper passes than the desktop Shapeoko line, but material still sets the limit: aluminum and steel need shallower depth per pass than wood, even on a rigid machine like this. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but push past what the material and bit allow and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the Carbide 3D Shapeoko HDM V3. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Shapeoko HDM V3 runs GRBL-based firmware (Carbide 3D’s Warthog, 4th-gen), so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender, including Carbide Motion. Select Shapeoko HDM in Easel’s machine menu to size the canvas to its 690 x 610 x 145 mm working area.
