Carbide 3D
Carbide 3D Shapeoko Pro
Production-ready CNC in three sizes, linear-rail upgrade over Shapeoko 4
A Carbide 3D Shapeoko Pro CNC machine.
The Shapeoko Pro comes in three sizes: Standard (17.5 x 17.5 x 4 in), XL (33 x 17.5 x 4 in), and XXL (33 x 33 x 4 in). It uses a 65mm trim router as a spindle (not included, recommended is the Carbide Compact Router, upgradeable to the Carbide VFD Spindle), 15mm linear rails on 15mm belts for greater rigidity than the Shapeoko 4’s V-wheels, and a leadscrew-driven Z-Plus Z-axis with heavy-duty linear bearings. Takes about 2-3 hours to assemble.
The Shapeoko Pro ships without a spindle: you supply a 65mm trim router (the Carbide Compact Router recommended, or any 65mm router like the Makita RT0701C), or upgrade to the Carbide VFD Spindle, so your actual RPM depends on what you install. 15mm linear rails on 15mm belts give it more rigidity than the Shapeoko 4’s V-wheels, and the leadscrew Z-Plus Z-axis holds up well, but it’s still a desktop-class machine, not an industrial one, especially on the larger XL and XXL sizes. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. Push too deep on the Shapeoko Pro and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material, so take shallower passes and work up. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the Carbide 3D Shapeoko Pro. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Shapeoko Pro runs GRBL firmware (not stated on Carbide 3D’s shop page, but confirmed by Carbide 3D’s own support site), so it connects directly to Easel over USB. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from Carbide Motion or another GRBL sender if you prefer. Select ‘Shapeoko Pro,’ ‘Shapeoko XL PRO,’ or ‘Shapeoko XXL Pro’ in Easel’s machine menu, matching your size, to size the canvas correctly.
