CNC4Newbie
CNC4Newbie HSNCxxxxRP
Rack-and-pinion CNC kit with UCcnc or Masso control, six working-area sizes
The HSNCxxxxRP covers six sizes on one build, described by CNC4Newbie as a ‘PIMPED version’ of the New-Carve with rack-and-pinion drive: 2424 at 26 x 26 x 7 in, 3636 at 38 x 38 x 7 in, 4824 at 50 x 26 x 7 in, 4836 at 50 x 38 x 7 in, 4848 at 50 x 50 x 7 in, and 4896 at 50 x 98 x 7 in (4.5 in clearance below the gantry using a 3/4in MDF wasteboard on all sizes). It runs rack-and-pinion drive on X/Y with an 8mm leadscrew on Z, 15mm square linear bearings on every axis, and 4 stepper motors. It can take a round-body spindle up to 2.2kW, not included; mount options run from 65mm up to 89mm.
The HSNCxxxxRP ships without a spindle, so its top RPM depends on whatever unit you mount, up to 2.2kW, check that unit’s own rating plate against the chart rather than assuming a number. Its rack-and-pinion X/Y drive and 15mm square linear bearings on every axis are a step up in rigidity from a plain leadscrew kit, closer to an industrial-style drive train. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. With a suitable spindle mounted, the HSNCxxxxRP can handle more depth per pass than CNC4Newbie’s leadscrew-driven kits, but still build up gradually. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the CNC4Newbie HSNCxxxxRP. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The HSNCxxxxRP runs on either the C4N Controller with UC100/UCCNC software, or an optional Masso G3 Touch closed-loop system, and neither is GRBL or FluidNC, so Easel’s live Driver and driverless Rapid Connect do not connect to or drive this machine. Instead, set up a Non-GRBL Machine Profile in Easel, design your project as usual, then use Project > Download G-code to save an .nc file. If your HSNCxxxxRP uses the UC100/UCCNC setup, open that .nc file directly in the UCCNC software on the PC wired to the machine and run it from there. If you have the Masso G3 Touch upgrade, transfer the .nc file to the controller over its built-in WiFi using Masso Link, or by USB drive, and run it from the touchscreen.
