CNC4Newbie
CNC4Newbie New-Carve CNC
CNC kit with explicit GRBL support, six working-area sizes
The New-Carve CNC covers six sizes on one build, CNC4Newbie’s only machine family with a dedicated GRBL settings guide and Easel setup instructions: 500 at 15 3/4 x 14 1/2 x 7 in, 750 at 25 3/4 x 24 1/4 x 7 in, 1000 at 35 1/2 x 34 x 7 in, 1045 at 35 1/2 x 52 x 7 in, and 4545 at 51 x 52 x 7 in (all with 4.5 in clearance under the X carriage); CNC4Newbie also sells a 4510 size option but does not publish its working area separately from the others. It runs 15mm square linear bearings and 12mm precision leadscrews with adjustable brass anti-backlash nuts on X and Y, direct-drive leadscrews with no belts, a square linear Z axis, a 2040 aluminum extrusion frame, and 6061-T6 aluminum motor mounts. Motors and electronics are not included by default; CNC4Newbie says you can wire up any GRBL-based controller, or add its own C4N Controller/UCcnc or Masso G3 Touch package.
The New-Carve doesn’t include a spindle, motors, or electronics by default, so its top RPM depends entirely on whatever GRBL controller and spindle or router you build it with, check that unit’s rating plate against the chart. Its 15mm square linear bearings and precision leadscrews with anti-backlash nuts on X/Y are solid for a self-sourced kit, but this is a lighter build than CNC4Newbie’s rack-and-pinion or ball-screw machines. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. The New-Carve falls short of that bar, so take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the CNC4Newbie New-Carve CNC. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The New-Carve CNC runs GRBL once you wire it up with a GRBL-based controller, the setup CNC4Newbie documents with its own dedicated GRBL settings guide, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender. Select your size (New Carve 500, 750, 1000, 1045, 4510, or 4545) in Easel’s machine menu to size the canvas. Note: if you instead build it with CNC4Newbie’s own C4N Controller/UCcnc or Masso G3 Touch add-on package, that is not GRBL and will not connect through the Easel Driver or Rapid Connect.
