CNC4Newbie
CNC4Newbie PRO 60120RP
Full-sheet cabinet-shop CNC with a choice of non-GRBL controller packages
A CNC4Newbie PRO 60120RP CNC machine.
The PRO 60120RP has a 62 x 122 x 8 in work area (76 x 139 x 64 in footprint using a 3/4in MDF wasteboard), built to handle a 5ft-wide sheet between the X sides and marketed for cabinet work. It runs rack-and-pinion drive with a belt reduction box on X/Y and a ballscrew on Z, 15mm square linear bearings on every axis, and 4 stepper motors. It can take a spindle up to 3kW, not included; mount options run from 65mm up to 89mm.
The PRO 60120RP ships without a spindle, so its top RPM depends on whatever unit you mount, up to 3kW, check that unit’s own rating plate against the chart rather than assuming a number. Its rack-and-pinion drive with a belt reduction box, ballscrew Z axis, and 15mm square linear bearings on every axis are built for real rigidity, sized for cabinet-shop work. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. With a suitably powerful spindle mounted, the PRO 60120RP gets close to that bar, but still build up depth per pass gradually and watch how the cut sounds. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the CNC4Newbie PRO 60120RP. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The PRO 60120RP ships with your choice of two non-GRBL controller setups: a PC-based Gecko G540/UC100 or UC400ETH stack run through UCCNC software, or a standalone Masso G3 Touch. Since neither is GRBL or FluidNC, Easel’s live control (the Easel Driver and Rapid Connect) does not drive this machine directly. Instead, set up a Non-GRBL Machine Profile in Easel, design your project, and use Project > Download G-code to save an .nc file. If your PRO 60120RP runs the Gecko/UC100/UC400ETH package, open that .nc file in UCCNC on the PC wired to the machine and run it from there. If it runs the Masso G3 Touch option, transfer the .nc file to the controller over its built-in WiFi using Masso Link, or by USB drive, and run it from the touchscreen.
