DIY CNC 3018
DIY CNC 3018 3018
Entry-level 3018-class CNC sold under many brand names
A DIY CNC 3018 3018 CNC machine.
This Easel menu entry covers the many white-label 3018-class CNC machines sold under dozens of different brand names, most sharing nearly identical mechanics from the same handful of factories. There is no single manufacturer behind the ‘3018’ name, so no exact spec can be validated against an official source for this entry. Machines in this class typically share a working area around 300 x 180 x 45 mm and run a GRBL controller, but the exact numbers vary by seller, so check your own machine’s listing or manual before relying on any figure here.
3018-class machines typically ship with a small brushed spindle motor, often in the 24V to 36V range with no published RPM chart, so check your own spindle’s plate or listing for its actual top speed before picking a number off the chart. These are light, compact machines built on small aluminum extrusion and leadscrews, not rigid production tools, so depth per pass is limited by the machine’s own stiffness. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. A small 3018 falls well short of that bar, and the fix is simple: take shallow passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the DIY CNC 3018 3018. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The 3018 runs GRBL on an Arduino Uno controller, with the exact version varying by seller, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender, including the SD-card control some kits ship with. Because this entry covers many different sellers’ machines rather than one validated product, confirm your own machine’s controller and working area against its listing or manual before you carve. Select 3018 in Easel’s machine menu to size the canvas.
