FoxAlien no longer sells this model, but owners can keep using it with Easel. The 3018-SE V2 is a compact desktop CNC with a 278 x 157 x 33 mm active working area and a 775-type 60W spindle (8,000 RPM). Its control board is based on open-source GRBL software. Specs were validated against an archived copy of the manufacturer’s page.
The 3018-SE V2’s 60W spindle tops out at 8,000 RPM, well below the chart, so leave it at 8,000 for everything and control the cut with feed rate. Soft woods, plywood, and acrylic are comfortable on this machine (speed the feed up if acrylic starts to melt), hard wood takes patience, and aluminum is engraving-only. Depth per pass is where the machine itself matters. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. A compact machine like this one falls short of that bar, and the fix is simple: take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the FoxAlien 3018-SE V2. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The FoxAlien 3018-SE V2 runs GRBL, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender. Select FoxAlien 3018-SE V2 in Easel’s machine menu to size the canvas.
