FoxAlien
FoxAlien 4040-XE
GRBL-based desktop CNC with 300W spindle
A FoxAlien 4040-XE CNC machine.
FoxAlien no longer sells this model new, but owners can keep using it with Easel. The 4040-XE is a desktop CNC with a 400 x 400 x 65 mm active working area, a 300W spindle, and NEMA 23 stepper motors. It is based on GRBL and compatible with GRBL-control software. It assembles in 15-30 minutes.
The 4040-XE’s 300W spindle cannot reach most of the speeds in the chart and loses torque fast below its top speed, so keep it near maximum and let the feed rate control the cut. Keep the RPM up for acrylic too, and speed up the feed if the edge starts to melt. Treat aluminum as light engraving only, with a single-flute bit. Depth per pass is where the machine itself matters. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. A light machine like this one falls short of that bar, and the fix is simple: take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the FoxAlien 4040-XE. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The FoxAlien 4040-XE runs GRBL, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code and run it from the machine’s SD card control if you prefer working offline. Select FoxAlien 4040-XE in Easel’s machine menu to size the canvas to its 400 x 400 x 65 mm working area.
