FoxAlien
FoxAlien Vasto
Final Sale: industrial-grade CNC with ball screws and linear rails
A FoxAlien Vasto CNC machine.
Final Sale: FoxAlien is retiring this model, but it remains fully supported in Easel. The Vasto is an industrial-grade CNC with a 400 x 400 x 100 mm cutting area, dual HG-15 linear rails with 16mm (XY) and 12mm (Z) ball screws, NEMA23 stepper motors with independent DM542 drivers, a 400W spindle, and open-source GRBL-based control. It assembles in 30-45 minutes.
The Vasto ships with a 400W spindle and also accepts 65mm trim routers (Makita RT0700C, DeWalt DWP611). FoxAlien doesn’t publish an RPM for the stock spindle, so treat the chart’s spindle-speed column as a reference rather than a dial setting: read the actual number off your spindle or router and keep the feed rate as your main control. Depth per pass is where the machine itself matters. The Vasto runs dual HG-15 linear rails with 16mm ball screws on X/Y and a 12mm ball screw on Z, a genuinely rigid drive train with very little backlash, so it can take deeper passes than a belt-and-wheel machine before the bit deflects or chatters. Spindle power is still the practical limit though: push too deep and the spindle bogs down (you’ll hear the RPM drop) rather than the frame flexing. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the FoxAlien Vasto. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
FoxAlien is retiring the Vasto, but it remains fully supported in Easel. The Vasto runs GRBL, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender. Select FoxAlien Vasto in Easel’s machine menu to size the canvas to its 400 x 400 x 100 mm cutting area.
