FoxAlien
FoxAlien XE-Ultra Core
Compact flagship platform for precision carving
A FoxAlien XE-Ultra Core CNC machine.
The FoxAlien XE-Ultra Core is a compact flagship CNC with a 440 x 440 x 120 mm working area, 16mm (XY) and 12mm (Z) ball screws with HG-15 linear rails, and closed-loop stepper motors. In the Easel machine menu it appears as ‘XE-Ultra Core with 1.5KW VFD Spindle Bundle Kit’.
In the Easel menu this machine is sold as the 1.5kW VFD spindle bundle, and that spindle can hit every speed in the chart, so set your RPM straight from it. If plastic starts to smear, slow the spindle down or speed up the feed. Depth per pass is where the machine itself matters. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. Few hobby machines check every one of those boxes, and the fix is simple: take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the FoxAlien XE-Ultra Core. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The FoxAlien XE-Ultra Core runs GRBL on its 32-bit control board, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender. Select “XE-Ultra Core with 1.5KW VFD Spindle Bundle Kit” in Easel’s machine menu to size the canvas to the 440 x 440 x 120 mm working area.
