FoxAlien
FoxAlien XE-Ultra
Flagship large-format CNC with ball screws and linear rails
A FoxAlien XE-Ultra CNC machine.
The FoxAlien XE-Ultra is the flagship large-format CNC with an 840 x 840 x 120 mm working area, 16mm (XY) and 12mm (Z) ball screws with HG-15 linear rails, and 60-86mm closed-loop stepper motors (2.6 N.m). Spindle and spoilboard are not included with the base machine.
The XE-Ultra ships without a spindle. Most owners install a 65mm trim router or FoxAlien’s 1.5kW VFD spindle, and either one can hit every speed in the chart, so set your RPM straight from it. If plastic starts to smear, slow the spindle down or speed up the feed. Depth per pass is where the machine itself matters. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. Few hobby machines check every one of those boxes, and the fix is simple: take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the FoxAlien XE-Ultra. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The FoxAlien XE-Ultra runs GRBL, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender. Select XE-Ultra in Easel’s machine menu to size the canvas to its 840 x 840 x 120 mm working area.
