Lunyee
Lunyee 3018 Pro Max
Entry-level CNC router with a 500W spindle and steel lead screws
The 3018 Pro Max is Lunyee’s entry-level all-metal CNC router, with a 300 x 180 x 80 mm working area, a 500W spindle (0 to 12,000 RPM), and Nema 17 stepper motors (1.68 A, 0.55 Nm torque) driving T8 stainless steel lead screws and 12mm hardened steel linear rods.
The 3018 Pro Max’s 500W spindle runs from 0 to 12,000 RPM, near the middle of most chip-load charts, so you have real range to match bit and material. Its lead-screw drive and hobby-scale frame are light duty, not a heavy industrial gantry, so depth per pass is where you have to be conservative. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. This machine falls short of that bar, so take shallower passes: push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the Lunyee 3018 Pro Max. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Lunyee 3018 Pro Max runs GRBL 1.1f-compatible firmware on a 32-bit ARM board, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code and run it standalone from an SD card, or use another sender. Select 3018 Pro Max in Easel’s machine menu to size the canvas to its 300 x 180 x 80 mm working area.
