Lunyee
Lunyee 4040 Turbo
All-metal CNC router with a 500W spindle and NEMA 23 motors
The 4040 Turbo is an all-metal CNC router with a 400 x 400 x 110 mm working area, a 500W spindle (a 1.5 to 2.2kW water-cooled spindle is available as an upgrade), and NEMA 23 stepper motors. It drives all three axes with optical axis guides paired with lead screws.
The 4040 Turbo ships with a 500W spindle as standard, with a 1.5 to 2.2kW water-cooled spindle available as an upgrade for harder cuts, but Lunyee does not publish a max RPM for either option, so check the plate on your spindle before you set chart speed. This machine’s NEMA 23 motors and optical-rail, lead-screw drive give it more mass and torque than Lunyee’s smaller 3018 and 4040 Pro routers, but depth per pass still comes down to rigidity, not spindle wattage. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. Start conservative and work up: push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the Lunyee 4040 Turbo. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The 4040 Turbo runs GRBL 1.1f, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender. Select 4040 Turbo CNC in Easel’s machine menu to size the canvas to the machine’s 400 x 400 x 110 mm working area.
