Maslow
Maslow M2
Chain-driven full-sheet CNC kit with GRBL control
A Maslow M2 CNC machine.
The M2 is a 4ft x 8ft x 3.8in (1.22m x 2.44m x 9.65cm) cutting volume machine, up to 32 sq ft, made by MakerMade as the successor to the original Maslow 2 design. It runs on industrial drive motors on all three axes with 11ft chains (15ft chains available), an all-metal Z-axis, and an Arduino DUE v1.2 control shield. It ships without a router: the 65mm metal router clamp standard (71mm or 91mm clamps available) fits bits from 1/8in to 1/2in depending on the router used.
MakerMade does not publish a spindle RPM for the M2 since you supply your own router, so check the plate on yours before you start. The M2 itself caps at 40 in/min (17mm/s) maximum cutting speed regardless of what the chip-load math returns, so treat that as a hard ceiling. A truly rigid, powerful setup can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a frame that will not flex, and enough mass to soak up vibration. Chain-driven machines like the M2 fall short of that bar, so take shallow passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the Maslow M2. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The M2 runs GRBL 1.1g on an Arduino Due control shield, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender. Select M2 in Easel’s machine menu to size the canvas.
