Maslow
Maslow Original Kit
Retired chain-driven CNC kit with a 4 x 8 foot work space
Maslow no longer sells this model, but it remains fully supported in Easel. The original Maslow CNC was a 4’ x 8’ work space kit, sized by the length of two #25 roller chains so it could be enlarged or shrunk by adding or removing links. A chain-and-sprocket triangulation sled pulled the tool around the sheet instead of a rigid gantry, and the kit shipped without a router: Maslow recommended a Ridgid R2200 (or an AEG MF 1400 KE in the EU), with cutting depth limited by that router’s own plunge travel of about 1.5in.
The original Maslow does not use a rigid X/Y gantry: two roller chains pull a sled around the workpiece, and cut depth depends on whatever router you supply rather than a spindle spec of its own, so check your router’s own RPM plate before you start. That sled geometry flexes more than a fixed gantry, so depth per pass matters even more here. A truly rigid, powerful setup can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a frame that will not flex, and enough mass to soak up vibration. The Maslow’s chain-sled design falls well short of that bar, so take shallow passes, and expect to make several passes through anything thicker than 3/4in plywood, which Maslow itself called the routine cut for the recommended router. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the Maslow Original Kit. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Maslow CNC (Original Kit) runs Maslow’s own firmware on an Arduino Mega 2560 with a custom Motor Shield, a proprietary control system that is not GRBL or FluidNC, so Easel’s live Driver and driverless Rapid Connect do not connect to it. To cut on this machine, set up a Non-GRBL Machine Profile in Easel, design your project, then use Project > Download G-code to save an .nc file. Load that file into Maslow’s own control software on the computer wired to the machine over USB, such as GroundControl or a compatible webcontrol interface, and run the cut from there.
