Meissa CNC
Meissa CNC Meissa 3
DIY 3D-printed CNC router build with a 20.5 x 14 x 2.5in working area
The Meissa 3 is a DIY CNC router: you 3D print the frame parts yourself (Meissa states 35 to 50 hours of print time for the full set) and assemble it around a 20.5 x 14 x 2.5in (520 x 356 x 63 mm) working area. It runs on 4 NEMA17 stepper motors with belt drive, controlled by GRBL firmware on an Arduino UNO board, and takes a compact router mounted in a 65mm or 70mm tool holder (router not included). It is a light-duty hobby machine, so plan on shallow passes.
Meissa CNC does not publish a spindle RPM for the Meissa 3 since you supply your own compact router (mounted in a 65mm or 70mm tool holder), so check the plate on yours before you start. As a 3D-printed DIY frame running on 4 NEMA17 steppers with belt drive, it does not have the mass or rigidity of a metal-frame router. A truly rigid, powerful machine can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a frame that will not flex, and enough mass to soak up vibration. The Meissa 3’s printed, belt-driven frame falls well short of that bar, so take shallow passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the Meissa CNC Meissa 3. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Meissa 3 runs GRBL firmware on its Arduino Uno board, so it connects to Easel as a standard GRBL device over USB. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender, including Meissa’s own PilotCNC (a GRBL-compatible sender). Select Meissa 3 in Easel’s machine menu to size the canvas.
