Meissa CNC
Meissa CNC Meissa 4
Build plans only; specs not published by the manufacturer
A Meissa CNC Meissa 4 CNC machine.
The Meissa 4 is a DIY 3D-printed router in the Meissa CNC family, sold as build plans and files. It has a belt-driven frame with NEMA 17 steppers and a working area of 355 x 520 mm (14 x 20.5 in). It runs GRBL on an Arduino Uno and takes a compact router that you supply yourself (not included). Because the frame is 3D-printed and belt-driven, it is a light-duty hobby machine, so plan on shallow, conservative passes.
The Meissa 4 is a belt-driven, 3D-printed router that takes a compact router you supply yourself, so treat it as a light-duty hobby machine and start conservative. As a general rule, a truly rigid, powerful machine can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a frame that will not flex, and enough mass to soak up vibration. A light 3D-printed frame on belt drive does not have that, so keep passes shallow. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the Meissa CNC Meissa 4. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Meissa 4 runs GRBL on an Arduino Uno over USB, so it connects directly to Easel. Install the Easel Driver and plug the machine in over USB, or use driverless Rapid Connect in a Chromium browser to drive it in real time. You can also export G-code from Easel or run Meissa CNC’s own PilotCNC sender. Design your project in Easel, generate the toolpaths, and carve.
