MillRight CNC
MillRight CNC Carve King 2 Mini
Compact CNC kit with GRBL control, sold as a Makita router bundle
A MillRight CNC Carve King 2 Mini CNC machine.
Millright CNC no longer sells this model, but it remains fully supported in Easel. The Carve King 2 Mini has about an 8 x 9 x 4 in working area, the same trapezoidal stainless lead screw and V-channel rail construction as the Carve King 2, and NEMA 17 stepper motors with dual drive on the Y axis. It was sold as a Makita RT0701C router bundle.
The Carve King 2 Mini was sold as a Makita RT0701C router bundle, but its RPM isn’t published on the archived page, check the router’s own speed dial against the chart. Its build, stainless lead screws and V-channel rails with Acetron V wheels, is a light hobby frame, not a heavy industrial one. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. The Carve King 2 Mini falls short of that bar, so take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the MillRight CNC Carve King 2 Mini. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Carve King 2 Mini runs GRBL, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender. Select Carve King 2 Mini in Easel’s machine menu to size the canvas.
