MillRight CNC
MillRight CNC Carve King
Entry-level CNC kit with GRBL control and V-slot rails
A MillRight CNC Carve King CNC machine.
Millright CNC no longer sells this model, but it remains fully supported in Easel. The Carve King has about a 17 x 17 x 4 in working area, trapezoidal lead screws with anti-backlash nuts and V-slot rails with polycarbonate V wheels on every axis, and NEMA 17 stepper motors with dual drive on the Y axis. It ships without a router, router mount, clamps, or end mills, so you supply your own spindle.
The Carve King doesn’t come with a spindle, so its top RPM depends entirely on whatever router you mount, check that unit’s own rating plate against the chart rather than assuming a number. Its build, trapezoidal lead screws and V-slot rails with polycarbonate V wheels, is a light hobby frame, not a heavy industrial one. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. The Carve King falls short of that bar, so take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the MillRight CNC Carve King. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Carve King runs GRBL, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender. Select Carve King in Easel’s machine menu to size the canvas to its 17 x 17 x 4 in working area.
