MillRight CNC
MillRight CNC M3
Compact CNC kit with a bundled Makita router and GRBL control
Millright CNC no longer sells this model, but it remains fully supported in Easel. The M3 has an over 260 x 260 x 50 mm (10.25 x 10.25 x 2 in) working area, a bundled Makita RT0701C router, 9mm fiberglass-reinforced GT2 timing belts on X and Y with V-slot rails, a belt-driven Z axis on linear rods for fast lifts, and NEMA 17 stepper motors.
The M3 ships with a Makita RT0701C router, but Millright CNC doesn’t publish its RPM on the product page, check the speed dial on the router itself against the chart. Its GT2 timing belts on X and Y and belt-driven Z axis make it a light, fast machine, not a rigid industrial one. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. The M3 falls short of that bar, so take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the MillRight CNC M3. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Millright CNC M3 runs GRBL, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender. Select M3 in Easel’s machine menu to size the canvas.
