MillRight CNC
MillRight CNC Mega V Pro
Large-format CNC with a pre-assembled Masso G3 Touch control system, two working-area sizes
The Mega V Pro covers two sizes on one build: Standard at 19 x 19.6 x 6 in (494 x 500 x 152 mm, about 5.5 in gantry clearance) and XL at 35 x 35.4 x 6 in (888 x 900 x 152 mm, about 5.5 in gantry clearance). It runs a 2HP air-cooled ER20 spindle (6,000 to 24,000 RPM), closed-loop stepper motors with encoders on rack-and-pinion X/Y drive and a trapezoidal lead screw Z axis, and MGN15 linear rails on every axis. It comes pre-assembled and pre-tested: mount the control stand, plug it in, and start machining.
The Mega V Pro’s 2HP air-cooled spindle runs 6,000 to 24,000 RPM, well above most of the chart below, so leave it at the chart’s recommended speed and control the cut with feed rate. Its closed-loop steppers with encoders, rack-and-pinion X/Y drive, and MGN15 linear rails on every axis are built for real rigidity. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration, and the Mega V Pro is built to that bar. Even so, push a pass past what the flute geometry and material can clear and it will deflect and chatter, leaving scalloped edges, or rub instead of cutting and burn the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the MillRight CNC Mega V Pro. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Mega V Pro ships with a Masso G3 Touch controller, a standalone touchscreen system that is not GRBL or FluidNC, so Easel’s live control (the Easel Driver and Rapid Connect) does not connect to it directly. Instead, set up a Non-GRBL Machine Profile for the Mega V Pro in Easel, design your project as usual, then use Project > Download G-code to save the toolpath as an .nc file. Transfer that file to the Masso G3 Touch over its built-in WiFi using Masso Link, or copy it to a USB drive and plug it into the controller, then open and run the file directly from the 15 in touchscreen.
