MillRight CNC
MillRight CNC Mega V / Mega V XL
Large-format CNC with rack-and-pinion drive, two working-area sizes
Millright CNC no longer sells this model, but it remains fully supported in Easel. The Mega V line covers two sizes on one build: the Standard has a 485 x 500 x 95 mm (19 x 19.6 x 3.75 in) working area and the XL has an 890 x 890 x 95 mm (35 x 35 x 3.75 in) working area. Both run a 120V, 1.25 horsepower Makita RT0701C router, rack-and-pinion drive on X and Y with a lead screw and anti-backlash nut on Z, MGN15 linear rails on Z, and NEMA 23 stepper motors. Millright CNC’s archived page for this model does not state a controller or firmware.
The Mega V’s 120V, 1.25 horsepower Makita RT0701C router doesn’t have a published RPM on this page, check the router’s own speed dial against the chart. Its rack-and-pinion X/Y drive and NEMA 23 steppers are a step up from Millright’s smaller kits, real mechanical advantage that resists deflection better than a lead-screw desktop machine. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. The Mega V gets closer to that bar than Millright’s smaller kits, but it is still a router, not an industrial spindle, so build up depth per pass gradually. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the MillRight CNC Mega V / Mega V XL. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Mega V runs GRBL, per MillRight CNC’s Quickstart Guide for Assembled Machines, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeros, and runs the job with live progress. You can also export G-code to run from another sender. Select Mega V or Mega V XL in Easel’s machine menu, matching your working-area size, to size the canvas.
