MillRight CNC
MillRight CNC Mega V2 Full Sheet
Full-sheet CNC with a choice of GRBL or Masso control
The Mega V 2 Full Sheet has a 97 x 50 x 5.25 in cutting area (6.25 in Z stroke), built to run a full sheet. It runs high-speed steel rack-and-pinion drive on X and Y with an improved screw-drive Z axis, linear profile rails on every axis with high-rigidity bearings on Y, and ships with a router mount for the DeWalt DW618 (router not included) or an optional 1.5kW or 2.2kW VFD spindle, with a 2.2kW automatic tool changer option. Assembly is required; instruction booklets are provided.
The Mega V 2 Full Sheet’s spindle depends on what you order: a router mount with no spindle included, or an optional 1.5kW or 2.2kW VFD spindle. Check whichever unit you have for its actual RPM against the chart. Its high-speed steel rack-and-pinion drive and linear profile rails, with high-rigidity bearings added on the Y axis to handle the extra span, are built for real rigidity across a full sheet. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. With the VFD spindle option, this machine gets close to that bar; with just a router mounted, treat it more conservatively and take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the MillRight CNC Mega V2 Full Sheet. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Mega V2 Full Sheet ships with a choice of controller. Order it with the standard GRBL Control System and it connects directly to Easel: install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress; you can also export G-code to run from another sender. Order it with the optional Masso G3 Touch Control instead and Easel does not connect to it in real time, since Easel’s live control works with GRBL, not Masso; design and generate G-code in Easel and run it from the Masso touchscreen. Select ‘Mega V2 Full Sheet’ in Easel’s machine menu for the GRBL version (or ‘Mega V2 Full Sheet (non-GRBL)’ for Masso) to size the canvas.
