MillRight CNC
MillRight CNC Mega V2
Large-format CNC with a choice of GRBL or Masso control, three working-area sizes
A MillRight CNC Mega V2 CNC machine.
The Mega V 2 covers three sizes on one build: Standard at 19 x 19 x 5.25 in (6.25 in Z stroke), XL at 35 x 35 x 5.25 in (6.25 in Z stroke), and XXL at 50 x 50 x 5.25 in (6.25 in Z stroke). It runs high-speed steel rack-and-pinion drive on X and Y with an improved screw-drive Z axis and linear profile rails on every axis, and ships with a router mount for the Makita RT0701C or DeWalt DW618 (router not included) or an optional 1.5kW or 2.2kW VFD spindle, with a 2.2kW automatic tool changer option. Assembly is required; instruction booklets are provided.
The Mega V 2’s spindle depends on what you order: a router mount with no spindle included, or an optional 1.5kW or 2.2kW VFD spindle. Check whichever unit you have for its actual RPM against the chart. Its high-speed steel rack-and-pinion drive and linear profile rails on every axis are built for real rigidity. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. With the VFD spindle option, the Mega V 2 gets close to that bar; with just a router mounted, treat it more conservatively and take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the MillRight CNC Mega V2. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Mega V2 ships standard with the GRBL Control System, so ordered that way it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender. If you instead order the optional Masso G3 Touch Control, that is a standalone touchscreen controller (WiFi), so design in Easel and export G-code to run from the Masso touchscreen rather than carving live. Select ‘Mega V2’ (or the matching XL/XXL size) in Easel’s machine menu for the GRBL build, or the ‘(non-GRBL)’ entries if you ordered Masso control, to size the canvas.
