MillRight CNC
MillRight CNC Power Route Max
Full-size CNC with ball screws and a choice of GRBL or Masso control
A MillRight CNC Power Route Max CNC machine.
The Power Route Max has a 1275 x 1275 x 158 mm (50 x 50 x 6.25 in) working area with 5.5 in gantry clearance. It runs 16mm precision ball screws on X and Y (dual on Y with an auto-squaring gantry) and a 12mm precision ball screw on Z, and ships with a router mount for the DeWalt DW618 (router not included) or an optional 1.5kW air-cooled, 2.2kW water-cooled, or 2.2kW automatic-tool-changer spindle. Assembly is required; expect at least a full weekend. It expands on Millright’s earlier Power Route Plus XL.
The Power Route Max’s spindle depends on what you order: a router mount with no spindle included, or an optional 1.5kW air-cooled or 2.2kW water-cooled VFD spindle. Check whichever unit you have for its actual RPM against the chart. Its dual ball screws on Y with an auto-squaring gantry and a ball-screw Z axis are built for real rigidity, a step up from the rack-and-pinion Mega V line. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. With the VFD spindle option, the Power Route Max gets close to that bar; with just a router mounted, treat it more conservatively and take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the MillRight CNC Power Route Max. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Power Route Max ships standard with GRBL, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender. If you order the optional Masso G3 Touch Control instead, its standalone touchscreen runs the job independently and does not connect through the Easel Driver, so export G-code from Easel and load it onto the Masso controller. Select ‘Power Route Max’ in Easel’s machine menu to size the canvas to its 1275 x 1275 x 158 mm working area.
