MillRight CNC
MillRight CNC Power Route Plus
Mid-size CNC with ball screws and a choice of GRBL or Masso control
A MillRight CNC Power Route Plus CNC machine.
The Power Route Plus has a 630 x 630 x 120 mm (24.8 x 24.8 x 4.7 in) working area with 5.5 in gantry clearance. It’s a redesign of Millright’s original Power Route, now running 16mm precision ball screws on X and Y (dual on Y) and a 12mm precision ball screw on Z, and ships with a router mount for the DeWalt DW618 (router not included) or an optional 1.5kW 120V ER20 VFD spindle.
The Power Route Plus’s spindle depends on what you order: a router mount with no spindle included, or an optional 1.5kW ER20 VFD spindle. Check whichever unit you have for its actual RPM against the chart. Its dual ball screws on Y and a ball-screw Z axis are built for real rigidity, a step up from the rack-and-pinion Mega V line. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. With the VFD spindle option, the Power Route Plus gets close to that bar; with just a router mounted, treat it more conservatively and take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the MillRight CNC Power Route Plus. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Power Route Plus ships with a choice of control system. Order it with the GRBL Control System and it connects directly to Easel: install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress, and you can also export G-code to run from another sender. Order it with Masso G3 Touch Control instead and you get a standalone industrial touchscreen controller that does not connect through the Easel Driver or Rapid Connect. Select ‘Power Route Plus’ in Easel’s machine menu to size the canvas for the GRBL version, or ‘Power Route Plus (non-GRBL)’ for the Masso version.
