MillRight CNC
MillRight CNC Power Route XL
Full-size, factory-assembled CNC with a bundled DeWalt router
A MillRight CNC Power Route XL CNC machine.
Millright CNC no longer sells this model, but it remains fully supported in Easel. The Power Route XL has a 1300 x 1275 x 128 mm (51 x 50 x 5 in) working area, a 120V, 2.25 horsepower DeWalt DWP618 router, 16mm precision ball screws on X and Y (dual on Y) with a 12mm ball screw on Z, and 20mm linear shaft rails. Millright CNC’s archived page for this model, sold before the Masso control option existed, does not state a controller or firmware.
The Power Route XL’s 120V, 2.25 horsepower DeWalt DWP618 router doesn’t have a published RPM on this page, check the router’s own speed dial against the chart. Its ball screws on X, Y, and Z with 20mm linear shaft rails are built for real rigidity. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. With a router rather than an industrial spindle mounted, take shallower passes and build up gradually. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the MillRight CNC Power Route XL. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Power Route XL’s controller isn’t documented by MillRight CNC, but it connects to Easel as a standard GRBL device over USB. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another GRBL sender like Universal G-Code Sender. Select ‘Power Route XL’ in Easel’s machine menu to size the canvas to its 1300 x 1275 x 128 mm working area.
