MillRight CNC
MillRight CNC Power Route
Mid-size CNC with a bundled DeWalt router
A MillRight CNC Power Route CNC machine.
Millright CNC no longer sells this model, but it remains fully supported in Easel. The Power Route has about a 25 x 25 x 4.7 in (630 x 630 x 120 mm) working area with 5.5 in (140 mm) of gantry clearance, a 120V, 2.25 horsepower DeWalt DWP618 router, 16mm supported linear shaft rails on X/Y and a 12mm supported linear shaft rail on Z, and NEMA-class stepper motors. Millright CNC’s archived page for this model does not state a controller or firmware.
The Power Route’s 120V, 2.25 horsepower DeWalt DWP618 router doesn’t have a published RPM on this page, check the router’s own speed dial against the chart. Its 16mm/12mm supported linear shaft rails give it a solid mid-size frame, a step up from Millright’s smaller belt-driven kits, but it is still a router-powered desktop machine. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. Build up depth per pass gradually on this machine. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the MillRight CNC Power Route. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
Millright CNC never published a controller or firmware for the Power Route, but it connects to Easel as a standard GRBL device over USB, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender. Select Power Route in Easel’s machine menu to size the canvas to its 25 x 25 x 4.7 in (630 x 630 x 120 mm) working area.
