MYSWEETY
MYSWEETY 4540
Desktop CNC router with a 500W spindle and touchscreen offline controller
A MYSWEETY 4540 CNC machine.
The Mysweety CNC 4540 is a desktop router with a 500W spindle running 0-11,000 RPM, a NEMA17 stepper motor (42 x 48mm), and GRBL control with an included touchscreen offline controller. Its working area is 430 x 390 x 90 mm (16.9 x 15.4 x 3.5 in).
The 4540’s 500W spindle runs up to 11,000 RPM, below most of the chart. Mysweety does not state a drive system (ball screw, lead screw, or belt) for this machine, so treat it as a mid-weight desktop router. Depth per pass is where the machine’s build sets the limit: a truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. Without a published drive system to confirm that, start with shallow passes and work up. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the MYSWEETY 4540. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Mysweety CNC 4540 runs GRBL, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender, or use the machine’s included touchscreen controller for standalone offline jobs. Select Mysweety CNC 4540 in Easel’s machine menu to size the canvas.
