The Mysweety CNC 3018 MAX is a compact desktop router with a 200W spindle (rated 200W, up to 300W max) running at 12,000 RPM, a stepper motor rated 1.3A/0.25N.m (42 x 48mm), and a T8 lead screw drive with a double copper anti-backlash nut. It connects with GRBL control and includes an offline controller. Its working area is 300 x 180 x 45 mm (11.8 x 7.1 x 1.8 in).
The 3018 MAX’s spindle runs at 12,000 RPM, in range for most of the chart. It’s a small machine on a T8 lead screw drive, so even with a capable spindle, treat it as light-duty: a truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. This machine’s size and drive system fall well short of that bar, so take shallow passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the MYSWEETY 3018 MAX. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Mysweety CNC 3018 MAX runs GRBL, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender, including the machine’s included offline controller. Select CNC 3018 MAX in Easel’s machine menu to size the canvas.
