NymoLabs
NymoLabs NBS-6040
Compact CNC with a stepless 710W spindle and ball screws on every axis
The NBS-6040 is NymoLabs’ compact router, with a 610 x 410 x 120 mm working area, a 710W stepless spindle (7,000-30,000 RPM), NEMA23 steppers, and linear rails with ball screws on every axis. It runs on open-source GRBL v1.1 with a 2.8 inch TFT touchscreen offline controller.
The NBS-6040’s stepless spindle runs 7,000 to 30,000 RPM, covering the full range of the chart, on NEMA23 steppers with linear rails and ball screws on every axis. That’s a rigid setup for a compact machine: it can take a confident pass, but depth still comes down to matching your bit and material to the spindle’s torque at that speed. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. Dial the spindle knob to the chart’s recommended RPM for your bit and material, and build up your depth from there. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the NymoLabs NBS-6040. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The NBS-6040 runs GRBL 1.1, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender. Select NBS-6040 in Easel’s machine menu to size the canvas.
