NymoLabs
NymoLabs NBS-6050 Ultra
Mid-size CNC with a 2.2kW spindle and closed-loop steppers
The NBS-6050 Ultra is NymoLabs’ mid-size router, with a 615 x 504 x 117 mm (24.21 x 19.84 x 4.61 in) working area, a 2.2kW air-cooled spindle (0-18,000 RPM), NEMA24 closed-loop steppers, and linear rails with ball screws on every axis. It runs GRBL with a 7 inch HD touchscreen controller.
The NBS-6050 Ultra’s 2.2kW spindle tops out at 18,000 RPM, near the top of the chart, on NEMA24 closed-loop steppers with linear rails and ball screws across every axis. That’s a rigid, powerful combination for a mid-size machine: it can take a confident pass, but build up to full depth rather than assuming it on day one. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the NymoLabs NBS-6050 Ultra. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The NBS-6050 Ultra runs GRBL, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from the machine’s 7-inch touchscreen controller or another sender. Select NBS-6050 Ultra in Easel’s machine menu to size the canvas.
