NymoLabs
NymoLabs NBX-5040
Compact CNC with a stepless 710W spindle and ball screws
The NBX-5040 is NymoLabs’ compact router, with a 508 x 408 x 97 mm working area, a 710W stepless spindle (7,000-30,000 RPM), NEMA23 steppers, and ball screws on every axis, with steel HSS linear tubes on the Y axis in place of a linear rail. It runs on open-source GRBL v1.1 with a 2.8 inch TFT touchscreen offline controller.
The NBX-5040’s stepless spindle runs 7,000 to 30,000 RPM, covering the full range of the chart, on NEMA23 steppers with ball screws on every axis. Its Y axis rides on steel HSS linear tubes rather than the linear rail NymoLabs uses on the NBS-6040, so it’s a step down in rigidity from that model. Take shallower passes here and build up gradually: push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the NymoLabs NBX-5040. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The NBX-5040 runs GRBL 1.1, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from the machine’s offline SD card touchscreen controller. Select NBX-5040 in Easel’s machine menu to size the canvas to its 508 x 408 x 97 mm working area.
