Onefinity
Onefinity Original Series X-35
Entry CNC in two cut areas on 35mm rail tubes with an optional Buildbotics controller
A Onefinity Original Series X-35 CNC machine.
Onefinity no longer sells this model, but it remains fully supported in Easel. The Original Series X-35 was sold in two cut areas: Woodworker at 32 1/8in x 32 1/8in x 5 1/4in and Machinist at 16in x 16in x 5 1/4in. Both ride on two 35mm hardened-steel rail tubes with sealed linear bearings and standard ball screws on every axis, and both used an optional BB Buildbotics controller with no router or spindle included; Onefinity recommended a Makita RT0701C router.
Onefinity didn’t state a stepper motor spec for this generation, and no spindle ships with the machine, so check your router or spindle’s actual RPM plate before you set feed rate. The mechanical build is real but modest: two 35mm rail tubes with sealed linear bearings and ball screws on every axis, not a heavy industrial gantry. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. Without a stated stepper spec to confirm that torque, lean conservative and take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the Onefinity Original Series X-35. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Onefinity Original Series X-35 runs the Buildbotics controller, which is not GRBL or FluidNC, so Easel’s live Driver and Rapid Connect cannot connect to it or run toolpaths in real time. To use Easel with this machine, set up a Non-GRBL Machine Profile in Easel, design your project as usual, then use Project > Download G-code to save the toolpaths as an .nc file. Because the Buildbotics controller connects over Ethernet or WiFi rather than USB, load that .nc file onto the controller through its network or web interface, then run the job from the controller’s own screen.
