Onefinity
Onefinity Original Series X-50
CNC in two cut areas on 50mm rails with an optional Buildbotics controller
A Onefinity Original Series X-50 CNC machine.
Onefinity no longer sells this model, but it remains fully supported in Easel. The Original Series X-50 was sold in two cut areas: Woodworker at 32 1/8in x 32 1/8in x 5 1/4in and Journeyman at 48 1/8in x 32 1/8in x 5 1/4in. Both ride on a 50mm hollow linear-motion shaft on X and two 35mm hollow shafts on Y, with sealed linear bearings, a 1616 ball screw, and a larger stepper motor rated up to 40% more torque than the X-35 generation; both used an optional BB Buildbotics controller with no router or spindle included.
Onefinity didn’t publish an exact NEMA size or torque figure for this generation’s stepper, only that it’s larger and up to 40% stronger than the X-35 version, and no spindle ships with the machine, so check your router or spindle’s actual RPM plate before you set feed rate. The mechanical build steps up from the X-35: a 50mm X-rail shaft, 35mm Y shafts, sealed linear bearings, and a faster 1616 ball screw. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. Without an exact stepper spec to confirm that torque, lean conservative and take shallower passes, working up as you learn the machine. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the Onefinity Original Series X-50. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Onefinity Original Series X-50 runs the Buildbotics controller, not GRBL or FluidNC, so Easel’s live Driver and driverless Rapid Connect cannot drive this machine directly. Instead, set up a Non-GRBL Machine Profile for this machine in Easel, design your project, and use Project > Download G-code to save the toolpath as an .nc file. Get that file onto the Buildbotics controller by loading it from a USB drive or by uploading it through the controller’s own network or web interface (accessible over Ethernet or WiFi at OneFinity.local), then run the job from the controller’s touchscreen or connected monitor.
