OpenBuilds
OpenBuilds LEAD CNC Machine 1010 (40 x 40 in)
730 x 810 mm lead-screw CNC with a BlackBox X32 controller
Openbuilds has shut down and no longer sells this model, but it remains fully supported in Easel for existing owners. The LEAD CNC Machine 1010 has a 730 x 810 x 100 mm (29 x 32 x 4 in) working area, ships without a spindle (OpenBuilds recommended a 65mm compact router, 710W), high-torque NEMA 23 stepper motors, and lead screw drive on all axes.
The LEAD CNC 1010 ships without a spindle: OpenBuilds recommended pairing it with a 65mm compact router (710W), so your actual top RPM depends on that router’s own speed dial, most trim routers run somewhere between 10,000 and 30,000 RPM. Lead screw drive and high-torque NEMA 23 steppers give it real rigidity for a machine this size, but at 730 x 810 mm it’s still a large gantry to keep from flexing under a deep cut. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. Take shallower passes until you know how this machine and your router handle a given material. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the OpenBuilds LEAD CNC Machine 1010 (40 x 40 in). If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Openbuilds LEAD CNC Machine 1010 runs grblHAL on its BlackBox X32 controller. Easel’s live control, the Easel Driver and Rapid Connect, works with classic GRBL and FluidNC over USB, so it does not carve this machine in real time. Use Easel to design and generate toolpaths, then export the G-code and run it from the machine’s own controller via OpenBuilds CONTROL over USB, WiFi, or SD card. Because Easel’s G-code is standard GRBL, it runs as-is. Select ‘Lead CNC 1010’ in Easel’s machine menu to size the canvas.
