OpenBuilds
OpenBuilds MiniMill
Small-format lead-screw CNC, bring your own router
An OpenBuilds MiniMill CNC machine.
Openbuilds has shut down and no longer sells this model, but it remains fully supported in Easel for existing owners. The MiniMill has a 120 x 180 x 80 mm (4.5 x 7 x 3 in) working area, ships without a spindle (OpenBuilds recommended a 65mm compact router, 710W), a NEMA 23 stepper motor, and lead screw drive on all axes.
The MiniMill ships without a spindle: OpenBuilds recommended pairing it with a 65mm compact router (710W), so your actual top RPM depends on that router’s own speed dial, most trim routers run somewhere between 10,000 and 30,000 RPM. Lead screw drive and a NEMA 23 stepper give it decent rigidity for its small footprint, but it’s still a light desktop-class frame, not a heavy industrial one. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. A lighter machine like this one falls short of that bar, and the fix is simple: take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the OpenBuilds MiniMill. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The MiniMill runs on OpenBuilds’ BlackBox Motion Control System X32, which uses grblHAL firmware. Easel’s live control, the Easel Driver and Rapid Connect, works with classic GRBL and FluidNC over USB, so it does not carve this machine in real time. Use Easel to design and generate toolpaths, then export the G-code and run it from the machine’s own controller, OpenBuilds CONTROL, over USB, WiFi, SD card, or Bluetooth. Because Easel’s G-code is standard GRBL, it runs as-is on the grblHAL-based BlackBox. Select MiniMill in Easel’s machine menu to size the canvas.
