OpenBuilds
OpenBuilds Sphinx 1050 (20 x 40 in)
Belt-and-lead-screw CNC bundle, motors and controller sold as add-ons
Openbuilds has shut down and no longer sells this model, but it remains fully supported in Easel for existing owners. The Sphinx 1050 has an 833.5 x 325 x 85 mm (32.8 x 12.8 x 3.3 in) working area. Its X axis runs on a 3GT/GT2 closed-loop timing belt, while the Y and Z axes use 8mm Acme lead screws. It was sold as a bundle: motors, the BlackBox controller, and a spindle (Dewalt DWP611 router) were order-time add-ons, not included by default.
The Sphinx 1050 was sold as a bundle: motors, the controller, and a spindle were all order-time options rather than included parts, so its actual RPM and rigidity depend entirely on what the original builder chose. Belt-and-lead-screw drive (a 3GT/GT2 closed-loop timing belt on X, 8mm Acme lead screws on Y and Z) is a solid base, but with motors as an optional add-on and a mid-size gantry, treat this as a lighter-duty machine unless you know your specific build used the high-torque motor option and a capable router. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. Take shallower passes until you know how your build performs. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the OpenBuilds Sphinx 1050 (20 x 40 in). If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Sphinx 1050 runs GRBL through its BlackBox controller, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender. Select Sphinx 1050 in Easel’s machine menu to size the canvas.
