OpenBuilds
OpenBuilds Sphinx 55 (20 x 20 in)
Compact lead-screw CNC bundle, motors and controller sold as add-ons
Openbuilds has shut down and no longer sells this model, but it remains fully supported in Easel for existing owners. The Sphinx 55 has a 333 x 325 x 85 mm (13 x 12.5 x 3.2 in) working area and lead screw drive on all axes. It was sold as a bundle: motors, the BlackBox controller, and a spindle (DeWalt DWP611 or RoutER11) were order-time add-ons, not included by default.
The Sphinx 55 was sold as a bundle: motors, the controller, and a spindle were all order-time options rather than included parts, so its actual RPM and rigidity depend entirely on what the original builder chose. Lead screw drive is a solid base for a machine this compact, but with motors as an optional add-on, treat this as a lighter-duty machine unless you know your specific build used the high-torque motor option and a capable router. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. Take shallower passes until you know how your build performs. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the OpenBuilds Sphinx 55 (20 x 20 in). If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Sphinx 55 runs grblHAL on the OpenBuilds BlackBox controller, an order-time add-on that OpenBuilds documents elsewhere as grblHAL-compatible firmware, though the machine’s own product page never states this. Easel’s live control, the Easel Driver and Rapid Connect, works with classic GRBL and FluidNC over USB, so it does not carve this machine in real time. Use Easel to design and generate toolpaths, then export the G-code and run it from the machine’s own controller, OpenBuilds CONTROL. Because Easel’s G-code is standard GRBL, it runs as-is on the BlackBox. OpenBuilds has shut down and no longer sells this model, but it remains selectable in Easel for existing owners. Select Sphinx 55 in Easel’s machine menu to size the canvas.
